ITM 3G revised lifter - Is this the correct one?
Speedstyle
40
22
Jan 7, 2003
Clawson, Michigan
I recently purchased some ITM 3g revised lifters part number 056-5137 off ebay. However, the lifters I received don't look like the ones on all the DSM vendor websites with the same part number. The box is stamped 056-5137 on the parts I received from ebay. The only picture I could find online that matches what I bought states the same part number but for EVO. As you can see the top portion is different.
Am I able to use these lifters I purchased in my 1991 Talon? See pictures attached.
The set you received is what you are supposed to receive now. Most of vendors are still using the older pic. I am not so sure exactly since when they switched the design but I am sure ITM and Topline have been using the same ones as you received for past 7~8 years. I have a new set of ITM lifters (056-5137) that came in about 5 years ago and they are the same as the ones you received. And all sets I received 10+ years ago were all looked the OEM style like the vendor's pic (The 1st pic).
Thank you for the confirmation and explanation. It is much appreciated!
