Street Build ITFLYS - 1Gina2G
ITFLYS - 95GSX 2.0L 6-Bolt Crank with 2G pistons, 1G TopEnd, with 2Gb-CamSensor and a Kiggly-CrankSensor - TD05H-Bastard 20G - E85 w 1000cc inj. ~25psi. Street driven track day car.
Now to start hardening the Interior trim plastic.
Before the epoxy, the smaller bits that are cracked and falling off get tacked together with superglue. The thin liquid seeps into the cracks, and improves handling for the steps ahead.
Got out the epoxy, ziplock bag, scissors and masking tape. Made a dam with the tape and created a valley to fill to strengthen the thin plastic support holding onto the screw mount.
Pushed some epoxy into the bag to mix:
Then I cut the corner of the bag and dispensed the mixed epoxy into the voids, and edges that could use some support
And a not pretty but done - support behind the plastic tabs.
Now leave it for 24hrs, and check it and hope all the epoxy has cured.
Looks like pb blast in the background raging again two oreilly
Panels look better than oem
Standard stuff for DSM work
new tool
The price was great - not built for speed, but if you don’t have a valve spring compressor, better than nothing!
I’ll see if this will allow for a valve stem seal replacement.
new tool
100% need the same thing done, so I’ll be waiting to see how it works out for you.
Pump the cylinder with compressed air through the spark plug hole and the valves should stay up. :thumb:
You ever done it with air?? If I tap on the spring to release the retainers, I'd worry that the tap would break the seal and release the pressure - allowing the valve to fall. That, and I don't have a fitting for my compression tester to put air into the piston.
I'm going to use nylon rope in the combustion chamber, and back up the rope with the piston.
On the cleanup bench, I took some time with a wire brush, carb cleaner, breakclean, and good old dawn soap in water.
before
after
ok, so on the big spring clip I used red abrasive pad on a 90deg angle grinder air tool.
not shown
The arm on the old WG actuator was crusty, so I abrasive pad grinder took it back to shiny with lots of pitting. I hit it with cold galvanizing spray, and probably finish it with Steelit, and now I see the old actuator is not the actuator I will be using, because the China E3 turbine housing has a different size flapper arm pin. So no need to finish it at the moment.
I use the hose from a compression tester kit. Youll have the cylinder at TDC. The piston will stop the valve if it does fall.
The dental floss method works well
i don’t know this sorcery
Remove intake CAM
97 CAM sensor needs threads to bolt up the trigger adaptor so I drilled and tapped the end of the 1G intake CAM:
17/64 tap drill
M8x1.25 taps - first the pointy ones, then the flat ended bottoming tap.
Lots of cutting oil, and compressed air to evacuate the shavings.
While I have the cover off, I located a 12pt 14mm deep socket, and checked to see if the ARP head studs are sill 90ft lb tight.
Only 3 moved at all, and only a few degrees.
successful I think 🤔
Here we continue with cam and valve work, Located a pile of new seals and gaskets:
Exaust CAM removed
And now turn the crank back to lower the #1 piston.
And I fed as much rope as I could into the cylinder. Note tape is protecting the piston from the end of the long driver, being used as a visual depth gauge while messing with crank position.
I advanced the crank by hand until the piston pushed all the rope up against the valves and head, holding light pressure to prevent valve pressure from moving the crank.
This allows the valve spring compressor to push the top down releasing the retainer clips.
Down to business, old seal comes off with long pliers.
And new seals go on, with a deep socket 10mm and hand pressure after an initial tap with a mallet.
Aw dang- see this is why we look close at the pictures. I f-ed up the one on the right. pushed it on too hard. Fixed it.
And the reverse - tricky part was getting the retainers into position with a light magnet on a stick, and getting it back inside the opening in the tool.
All rope removed and everything timed to TDC, and then the CAMs go in. CAM guard lube.
Timing belt back on
So annoying setting the tension in the car. Trial and error finally gets it so the tensioner pin slides out smoothly.
Cover on, and now the new 97 CAM sensor housing can go on.
CAM sensor adaptor installed
Brick by brick - The 97 CAS fits the space better than the 1G black top CAS. This is possible to use now that a Kiggly crank sensor is installed. I'm looking forward to seeing how stable these two sensors perform.
I like this shot of the water lines
Lets see the list:
Phase 1 (Exterior)
Things to locate:
2” thick 2Ga Eclipse door caps - Looking!
Body Shop:
Paint 2Ga door caps
Protective film install
Phase 2 (Engine and Interior)
Things to locate:
Grey plastic interior door switch trim - Looking!
Low profile adjustable CAM gear hardware for AEM gears (completed)
Valve spring compressor (completed)
In progress:
Hood Latch clearance (completed)
Interior Mirror Trim - epoxy reinforcement (completed)
Cyl 1 Valve guide seals (completed!)
Drill and tap 1G intake cam for 2Gb CAS (completed!)
2Gb CAS install - (completed)
Wiring for 2Gb CAS (completed)
TD05H turbo rebuild
Refinish 3" exhaust components
Front bumper brackets and misc powder coating
Hot parts refurbish (spot welding)
New sensor, new wiring harness
This pops up here next to the egr valve, and goes under the Intake Manifold.
behind the engine, and over to a bracket hanging on the timing cover, 2Ga style
hot today
So, I am learning. The “upgrade” TD05H rebuild kit thrust washers needs a little more than the stock cartridge allows, so I’m working out how.
