Is this turbo any good? garrett t04b v-trim?
prophecy7115
345
4
Apr 23, 2005
Miami, Florida
how good is the Garrett T04B V-Trim Turbocharger from bullseye racing? it states it flows 48lbs a min, see ill be honest my t-25 took a sh!t, and now i am looking for a turbo, and i plan on getting 300ish hp, and i am good for it, and i really dont want to be maxing anything out on my car at that power, and i dont want to spend money on another factory turbo until i get all my supporting mods, i will get larger turbo for 300ish hp and run it low until i get the fuel wich should be reall soon, but is this turbo any good? i need to get my car running any way really soon so any advice would help. thank you. And for those of you who dont like spending money twice! i understand! so please understand my situation.
If 300 is all that you're looking for Evo3 16g would be more than enough with much better spool.
Well when there are posts like this...
RavenX said:
I used the Vtrim. I had to get rid of it because it would surge on my built 6 bolt at only 18psi while other people running stock motors were pulling almost 400whp which was really odd to me. In the end i went for the t04b 50trim and haven't looked back ever since. According to dave the vtrim is not a very forgiving turbo because of the map. Its up to you which one you want but i would just get the 50trim since its tried and true. As for how much boost you can run on 550's i would stop around 17-18psi if that just watch your duty cycles and make sure you don't hit 100%
...in threads like this, along with other endless discussion about Bullseye stuff, I hope you can formulate a good opinion for yourself. Take note at what I specifically set in bold print in the above quote; "dave" is referring to Dave Hall, the Bullseye guy. Whenever I decide to work on my car, I will hit 300 whp on race gas with the 14B so you should not have any problem hitting that mark with the Evo 3 16G as oldman suggessted.
I really appreciate all the help, i have searched and it was probably silly for me to post the thread due to all the talk on this turbo, but i wanted to buy one turbo and thats it, i didn't want to waste my money twice and since i was looking for a 320 whp base i figured this t04b turbo might be some help, Well once again any comments are greatly appreciated.
And my setup obviously is not for anything greater than a 14b but my setup is not going to stay like that for long, and since i need a turbo urgent i figured spend the money right.
