Is this stuff good?
Status
Not open for further replies.
I have stock exhaust system and my header is crack so i was looking for header for sale. But, I saw this and it is including everything the whole exhaust system and good price that i can afford. There one thing, is this exhaust system is good or anybody have experience on those? STAINLESS STEEL CAT BACK CATBACK EXHAUST SYSTEM+HEADER 95-99 ECLIPSE NT 2G NA | eBay
ebay exhaust its ok
the only problem you will not have a cat
second your check engine will stay on if you can get something to simulate the rear o2
ebay exhaust its ok
true but all these street racer have no cat back anyway, also did u know catback make your car slow little bit? (maybe alot). It what i heard and i believe i guess.
Acully you dont gain much from not runing a cat if anything you lose power. Also using a catback exhaust system you gain quite a bit of power over stock because your gainig more flow.
your right. that the point what im trying to say.
actually you both are wrong unless you use a high flow cat but those are crappy not using a cat increases more airflow and hp gains, most street racers by a catless downpipe and an exhaust with a high flow resonator cats are so restrictive
and if your a road racer most of the time have a stainless steel pipe coming out the back tha spits fire
why why why do people post on things they have noooooooooooooo clue about... really? jesus christ...
a cold air intake with a good filter, + header, and cat back exhaust will gain you about 5-10 HP. but mostly it will move the power curve more towards the top end.
if you have no cat, maybe another extra 1-2 hp.
Nice. Two threads, same question topic. Post your questions in the thread you've already started...
http://www.dsmtuners.com/forums/newbie-forum/439935-looking-header.html#post153019200
OR you could search our site since you aren't the first wondering if eBay parts are good or not.
http://www.dsmtuners.com/forums/420a-bolt-tech/389819-good-exhaust-ebay.html
http://www.dsmtuners.com/forums/420a-bolt-tech/397727-420a-exhaust-system.html
http://www.dsmtuners.com/forums/420a-bolt-tech/394087-ebay-exhaust.html
Closed.
:dsm:
Status
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
