Is this head safe????
guamboyeli
125
May 24, 2012
North las vegas, Nevada
is this head still ok to use....it seems ok...i dont know what the brown stuff is... i dont want to put money into it and have it not handle the heat
Bet that is where somebody wedged a wrench to break a cam bolt loose and cracked the casting.
Not pretty, but will work as long as it doesn't leak.
But if you are going for any sort of built head, find a nice casting.
Or you could take it to a welder and see if they could knock out the JB weld and actually lay a bead on the crack/hole that was patched with JB weld.
Save it as a back up, or a flip on a stock engine.....
Decent heads are getting harder to fine, that are anywhere close to a min spec thickness
