Is this $250 HKS MLS Head Gasket Trash?
Stunn3r
5+ Year Contributor
77
27
Nov 1, 2019
Rockland, New York
Hey, I was prepping for the cylinder head to be installed and noticed some ARP Lube on the HKS MLS head gasket. I sprayed some brake clean so it could easily come off. After I wiped it off I noticed immediately some of the Viton rubber coating was removed.
Is this gasket usable or throw it in the trash?
Thanks.
Info: Cylinder Head and Block have been both been machined.
That coating is usually just for extra sealing to compensate block/head surface rough finish. The embossed part is the one would actually seal. I would use copper spray to coat and send it.
Would you completely remove all the Viton coating, then spray the copper spray or just spray it as is?
I wouldn't probably remove the rest of coating. I would just cover with the copper spray as is (but degrease well on gasket/head/block surface). The HKS head gasket has the beaded sealing on each coolant hole independently, so I wouldn't be worried much as long as if the head/block surface finish/flatness is fine.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
