eddyspaghetti
- 120
- 17
- Mar 27, 2016
san francisco,
California
Hello, I drive an1997 Mitsubishi eclipse GSX 7 bolt engine, my cams timing is correct but I wanted to know if my crank time mark is off? I manually cranked the engine 6 times before I took the timing belt off and this is where I ended up. what should I do next if its off? The timing belt is off right now, and since this is my first time doing this job, im not sure. Am I ok to taking off the cam lock and cranking the engine again? Or do I need to install and tighten the timing belt THEN manually crank the engine? If so how many more times? Any help would be much appreciated thank you
