August578
5+ Year Contributor
- 101
- 28
- Jun 15, 2021
Eastvale,
California
Hi quick question I'm upgrading to an fp green and wanted to know if I safe to run valvoline vr1 20w-50 oil straight up. I have a 4g64 btw
I know this topic is everywhere but just wanted to make sure I don't have to have certain clearances to run this oil.
Thanks
Thanks
you can't run 20w50 in a stock motor blah blah.... but chances are the motor has 100k+ miles on it now, everything is worn and oil pressure is lower than it once was to begin with.
. I’ve got about 650 on it so far with fantastic oil pressure on 10w-30 conventional, 85-90psi cold and 28psi warm idle, this is currently in colder Wyoming winter weather, should I just stay at a conventional 10w-30? The motor seems happy so far with it
