is fadanza ok
I have used fidanza before with no problems. I haven't used the items you are looking at tho.
Their lightweight flywheels are top notch. I only know a few that have used their clutch but they arent complaining about it!
I run their 4.3 clutch and the aluminum flywheel. IMO their flywheel is one of the best hands down due to the replaceable friction surface. Yes their clutches are going through a change but I preferred the 4.3 over the ACT 2600 I ran.
i found that a fidanza pressure plate ($150) with a act solid six puck gives you a greater air gap between disc, flywheel, and pressure plate vs the act2600 with a 6puck. this helps reduce clucth drag. also the fidanza pp is 2300 so its not as stiff as acts pp. this setup has been holding in my 475whp 395wtq daily driver for awhile now.
