interior lights dont work....
Levesque
152
Apr 19, 2009
Chicoutimi, QC, Canada
guys the fuse is good.
I was think the light bulbs but would they all be burnt? cluster? HVAC controls?
none of those work ? its for a 1gb the lights on the roof work.. just nothing else.. the light near the fuse box works also... the ignition key light also.
any ideas? going to check the bulbs just not sure where the other bulbs are for the other controls other then the cluster.
Check the wiring coming from the turn signal switch. Could be that the harness connector has came loose which is inside the steering column and you have to take off the column covers to check.
Also, the connection to the instrument cluster could have worked loose as well in which you need to take the cluster out and check on this area..
Hope this helps ... - DSM
will check what fuse is for the interior lights? or is the cluster fuse for that also.
interior lights as the ones around the heat controls etc
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
