dash lights/deforst dont work
rkn527
64
May 9, 2004
capitol heights, Maryland
i bought a 95 awd tsi and the hazards,cluster,turn signals and reaf def has no power at all. the head lights and brake light work i checked the fuse and i switched the signal relay and some thing can come one help me i can get this this on the road with out these things working thanks in advance
i the flashers dont work but brake lights do then it might be bulb but probly not, first thing to check is locate your flasher in the fuses and see if it even has current to send to the switch itself. If you have current going through it then check the switches for current out when the switch is on.
And remember when in doubt check the fuses 1 more time :)
If you need any wire diagrams let me know
