lights on complete dash dont work..
codeofdastreets
505
3
Sep 25, 2008
dunedin, Florida
I'm pretty sure it"s a fuse or loose ground.. I looked at the fuses under there dash and they appear to be all good.. Is there a specfic fuse you guys can pin-point for me to check??
Which lights aren't working?
I had the same problem and likely have the fix for this if you can provide a little bit more information.
Center console lights, dash lights, cluster lights.. Basically all the lights controlled by dimmer
Did you happen to just install a radio? I'm thinking blown dimmer switch (reostat).
No radio was installed, but dimmer does makes sense.. When I get a chance I will disconect dimmmer nd put it straight into the light switch..
