Both power windows and interior lights dont work...good fuses
The relay is located on the driver side under the dash. Heres a diagram. (This is the behind the kick panel)
As far as the radio, check your wiring and make sure that everything has a good connection. Whenever I have a problem it's usually my ground wire.
As of interior lights, do you mean dash lights also? If so check the grounds on the driver's side kick panel for a really good connection. If that doesn't fix it chech the dimmer switch. It may interfere with the rest of the electrical system. Do you have tail lights. If no, check fuse #5 and the wiring to that fuse. I hope this helps you.
Try wiggling the ignition switch to see if it has a poor connection or short. This is the time to buy a power probe 3. It's a lifesaver for electrical diagnosis.
Problem fixed...my battery is in the trunk so I have a distribution box under engine bay...turned out one of the power wires going to that dist. box was loose..easy fix...thanks for helping everyone
