wret
- 2,931
- 91
- Jul 3, 2003
Bel Air,
Maryland
Why don't you just run some extra hose from your windshield washer reservoir to your intercooler. You could valve it or splice it back and forth when you need it.
Flame away!Originally posted by Tallen
with the $ you spend on a squirt gun (pfffftfttt) you could buy a stock fuel pump and a nozzle from home depot and make your own cool little kit. dont leave out some parts from the shack like wire and a switch.
Anything that lowers the freezing point of water is a good idea, being that if it did ever get to freezing, remember that water is an odd liquid that actually EXPANDS upon freezing, causing tanks to blow up and tears to be shed...
I must say, this is 10x better than using a super-soaker.
Living in LA has its negatives.to corrode just about anything you spray it on.Originally posted by alIan
a water/salt mix would work
Originally posted by BlueMoonEclipse
the NX setup is N2O free....its just a CO2 cooling system
Compressing the air will heat it up, but it will eventually return to room temperature in the bottle, then being cold when it comes out. I think it could work.Originally posted by need4speed-gst
well those real tite factory tuned 03 evo lancer turbos come with that mod...
Originally posted by turbohappy
Would you be able to use compressed air? Seems like it would work (although maybe not quite as well). Then you could fill it up with an air compressor, or somehow set it up an air compressor in the car to fill it up when you are coasting Compressing the air will heat it up, but it will eventually return to room temperature in the bottle, then being cold when it comes out. I think it could work..
wrong my friend...the N-tercooler setup of NX is a co2 setup.. other cooling setups using n2o are not the N-tercooler setup (which is advertised by NX as n2o free btw... do some research)
