Intercooler Sprayer [Merged 12-7] sprayers ic i/c fmic sidemount smic co2 water
Yea...I thought of that but I already removed the ac and lines...But I was going to use brake lines and drill like 3 pinholes into it.
Whatever you end up doing, write a DIY anyways.
Yes..I think im going to start it next weekend. But what I want to do is instead of using the wiper switch I will find the wire that sends the power to the pump and hook that to a switch.
There are plenty of writeups on this subject, since it's been asked about a bajillion times. ;) I even remember an SMIC writeup when the guy used thing copper tubing and made a funky spiral around his SMIC. :p
But are there write ups using the rear sprayer setup though? I couldn't find any.
i used the rear window washer bottle for my i/c sprayer.. i went to lowes/home depot and got the refridgerator ice/water line (i used that cause i figured, hell it holds at least 150 psi water pressure in a house)... .... i hooked into the squirter lines from the rear washer bottle and then ran the lines up to the front of the car through the interior (under the carpet) and then drilled about 20 really small (smallest drill bit i could find) into a 30" piece of brake line... i mounted it up under the bumper support (so you cant see it) and made the holes face to the intercooler, o.... by the way.... you have to crimp one end of the brake line and soldier it so it wont leak,.... after its mounted, get a 1 way valve, (pet store) and make sure to put it in-line and make sure it points the right way.... the one way valve is so that when you spray, then stop, the water doesnt come all the way back through the lines... that when when you spray again, it is ready... the closer to the "line with holes" you put the valve, then the faster it will start spraying when you hit the switch.. then hook your lines up and and run wires from a momentary switch or a toggle switch and wa la... intercooler sprayer... i opened the hole up in my rear washer bottle so i could get ICE into it... that way the water iss ice cold to cool it... good luck guys....
I'd say revival... now that I've found E85 I no longer have ICing concerns of any kind.
