Intake manifold on turbo app. Need info (help)
xX-ProudDSM-Xx
96
Jul 16, 2011
Pomona, California
Well I'm getting a aftermarket intake manifold soon. I wanted to know what do I benefit? Like do I get more hp,higher psi, etc. I dnt know what the brand is but it was going to with a 70mm turbo,so you guys can get a idea on how big it is.
Its called the search button. Troll!
It's called telling members to search is not an acceptable answer troll! :rolleyes: help answer the question or GTFO. :notgood:
What kind of mods do you have. your profile only says you have a header. They generally open things up in the top end, and sacrifice low end, but it's hard to say without having it on a dyno, and it will depend on alot of other factors as well. List what you got so we can help you further. The turbo is only one piece of the pie here.
My GST. The GST already has the turbo put in. I'm just getting the intake manifold of some guy that had it with his kit, he has a 70mm turbo nd 1000cc injectors so I think he was trying to hit hard. The intake manifold is pretty big. So if I get it would I get more hp,higher psi,greater air flow, I just dnt know? That's why I was asking like what benefits or performance do I get with putting this in.
Update your profile to reflect your vehicle that will be the main modded one. There is the garage option that will allow you to list multiple vehicles and mods, however, everyone will look at your main listed vehicle. Update the information as accurately as possible.
Note, bigger isn't always better, cheap parts are more often than not cheap quality. With that said, I would go with a JMFab SSIM if you have a 7 bolt head. If you have a 6 bolt head then I would go with the Magnus cast manifold.
Oh well honestly guys I really don't know what brand manifold it is. Don't know what cams I have. It came with the car when I bought it. I'm 17 years old so really dnt know much. Just couple of stuff on turbo details. How would I tell what cams I have?? And how would I find would I find out what intake manifold I have?
For the cams you need to take the valve cover off and get some pictures of any markings on the cam sticks (number/letter configurations). Take a picture of the intake manifold.
I'm sorry, but I don't think you should be worried about mods such as this yet. You have a stock car, and seem to have minimal knowledge of turbocharged cars.
You must learn to walk, before you can run.
True.but I do know some stuff about turbo things. As right now I dnt have a picture of the intake manifold. But again am I looking at more hp??
Not nesissarly. Going with the wrong intake manifold can cause increased lag and loose performance. You need a goal for your car. Street drive, track, rpm limit, etc.
Well its my daily driver. Main point I'm looking for is a increase in hp or in turbo psi. If it doesn't help none of those then I mostly wouldn't want it. So it give me no hp or higher psi right?
