TalonJohn94
- 590
- 4
- Jan 30, 2003
Milwaukee,
Wisconsin
I had to pull out my HLA's to bleed them. It wasn't too difficult to pry the rocker arms off with the cams installed, in order to pull the lifters out.
According to the VFAQ, I should Use the flat-bladed screwdriver underneath the rocker as a lever to lift rocker arm end onto the lifter tip. I don't know if its because I had my machinist use +1mm valves on the valve job -- but it seems impossible to reinstall the rocker arms under the cams.
Any tricks?
Any tricks?
