Resolved installed 1g bov in 2g eclipse now have several issues
TurboSpider
223
17
Nov 2, 2015
York, Pennsylvania
OK I installed 1 Gen bov today on my 97 eclipse, I also install an aftermarket boost gauge. With the stock 2nd gen BOV installed the car would make 15 psi max. After installing the 1st generation BOV the car would go all the way up to 20 psi which is where the boost gauge maxes out. After installing the 1st gen
BOV the car has gained a lot more top and and power it drives almost like a new vehicle now. However, Once the car hits 20 psi it feels like the car hit a brick wall. Sometimes a backfiring type sound is heard from possibly in the intake. As far as I know the car has a stock boost controller and everything else besides the intake is stock. I recirculated the blow off valve using the same rubber hose that connected the second gen BOV. Everything seems to be tight as far as I can tell. Also I noticed when the car is revved up slightly or when pulling up to a stop sign and the rpms are dropping a high pitched whistling sound can be heard coming from the intake. I disconnected the rubber hose that recirculates the blow off valve to the air intake and just reved it slightly not much at all and it appears the whistling sound is coming from the blow off valve it's not the sound of the whoosh sound that it normally makes but a high pitched whistle that happens for about a second as the idle drops. If I let off the throttle before it gets to 20 psi and feather the throttle to keep it below 20 psi it doesn't cut out and it runs fine under normal driving conditions. It seems like the problem is it is developing too much boost is it experiencing fuel cut or something else what would cause it to be boosting up to 20 psi stock without a boost controller or anything like that.
What do you guys normally seal the valve cover breather with when doing a leak test?
I just stick a bolt in the hose and clamp it down tight.
