diambo4life
- 1,978
- 1,080
- Apr 18, 2002
Oklahoma
As far as power goes, my new setup is going to include Bluemax 1850cc injectors, E85, cams, smim, and an HX35 on 30+ psi with the BEP vband housing on a twinscroll manifold. Thank you for mentioning flow vs pressure, vs voltage, I forgot to put that in, and many people fail to take this into consideration, and if you look at the numbers, the 255 really falls short at higher pressure levels, especially on corn juice. Diambo, I noticed you ran the time in your sig on pump gas. Have you ever tuned on e85 with your setup?
Also, Diambo, what is your base fuel pressure utilizing the factory regulator with your setup? Ive ran a 255 for years, and just use an AFPR because everyone says you suffer fpr overrun with a 255, so I never tried running with the stocker, but I am now curious about this...
My times were run on pump E85. Not on straight gasoline. My BFP is stock ie. 37-38psi.
With your setup, even a single pump like the Bosch 044 or the new Jay Racing pump will suffice. I did run a 10.7@138mph on only a Bosch 044 too on E85 (before I added the inline) so I know it can handle the power just fine. Just lower the base fuel pressure a little.
