Inline fuel pump
Status
Not open for further replies.
eclipsalon
283
Sep 29, 2010
rosenberg, Texas
I've replaced the fuel tank with a cell, so i got a Ive replaced the fuel tank with a cell, so i got a aero inline. I have the pump wired to the stock aero inline. I have the pump wired to the stock pump connections pump connections and ive tested the wires to and ive tested the wires to make sure there still getting power; there good. make sure there still getting power; there good. The pump is inbetween the filter and the cell. The pump is inbetween the filter and the cell. Ive seen most ppl put theres after the filter. Ive seen most ppl put theres after the filter. Could this be why the pump isnt kicking on? Could this be why the pump isnt kicking on?
Ps. I've also tried running the pump direct to Ps. I've also tried running the pump direct to the battery (before i pulled out the MM) and it the battery (before i pulled out the MM) and it sparked a bit. Almost as if + and- were sparked a bit. Almost as if + and- were touching, but im 100% sure there not and + is touching, but im 100% sure there not and + is on +.
Status
