injectors question
JiveMasterT
1,848
9
Jan 3, 2004
Chest of Westerson, New York
im going to start doing supporting mods for an eventual turbo upgrade. my question is, if i put in 660 injectors without putting in a new fuel pump or doing any sort of tuning, will my car run right?
Originally posted by LightningGSX
No
ok, what if i did 660 injectors, a fuel pump, fuel rail, and fuel pressure regulator? is that the better way to go? i need a little more info than a simple no.
If you are going with a bigger turbo soon, i would also get a larger fuel pump (255), a fuel pressure regulator, and rewire the pump.
im trying to stay away from an electronic a/f controller because my friend has one and its a royal pain in the ass. i could just use a boost dependant fuel pressure regulator, right?
Unfortunately, if you want to install larger injectors, at least an ECU piggyback device is necessary. As well, a larger fuel pump is going to be necessary, and possibly the fuel pump rewire. The fuel rails in DSMs are supposed to have quite a lot of headroom.
You could start by going to a larger fuel pump and an adjustable FPR. I run a 190lph fuel pump with no additional fuel mods on an FP Big28@16-17psi (Depending on weather) without issue. If you go with a larger fuel pump than 190lph, such as 255lph, then an adjustable FPR would probably be a good idea.
