550cc injectors question
Something i never used a safc, but i use a gm maft set up with a logger, and ill be adding my wideband into the mix this spring. Looking foward to using dsmlink v3 soon also.
with the money your going to spend getting a program that you can use to tune your car you might as well get dsmlink you should the new light version is coming out pretty soon later this mounth i hear
