Justin DuBois
DSM Wiseman
- 3,341
- 3,312
- Aug 15, 2019
Oakland,
California
I’m looking for the practical wisdom regards injector sizing related to the fuel pump.
I assume there is a practical limit to the size injector you can pair with a fuel pump.
Example: At some point a stock fuel pump/filter/-6an supply wont have enough flow to hold pressure at WOT with a xxx size injector.
What is that practical limit?
What pump do you pair with x size injector?
In my case I’m running -6an supply, stock fpr, stock return.
I’ve been very happy with 380hp using 720cc injectors and a Supra 280lph pump.
If I move to 1000cc injectors (or larger) what else has to change? and practically - how do you know what has to change and by how much?
