injectors and dsmlink
mkspriggs
164
May 21, 2004
clovis, New Mexico
i was just wondering what would be to big of injectors for a street/race car with dsmlink?or can i go as big as i want and set dsmlink lower on street and change it when i race?thanks guys :dsm:
You can go pretty big on the injectors with dsmlink. Unlike a piggyback system you don't have to alter the airflow values to trick the ecu into trying to run larger than stock injectors.
I have no idea what you are asking for your second question. With DSM link, you program it for whatever injectors you're using and tune from there.
i was saying if i put 1000cc injectors on,can i somehow make it flow less whil;e on the street?or will it even make a difference?
Its going to flow based on the amount of air you are pushing into the engine. So if you are driving around not getting on it then it automatically won't spray as much fuel or won't hold the injectors open for as long.
ok thanks alot thats what i was wondering i diddnt want to be hitting up the gas station twice a day
