Initial settings for S-AFC - everyone's opinion
i have a 60 trim turbo, 660 injectors, 255 lp, 2g mas, fpr@40 psi, and fmic. i run 20 psi of boost on pump. i know that i should be in the negitive on the high setting, but if i try to go there my cars spudders. i let off right away. also my o2 leans out bad. i am guessing that i should be like -15 or -20, but i just think its gonna blow if i go there. and yes i start to get knock. but i have been told that i have black smoke comming out the exhaust. and it seems to run way richer when i am driving on the highway. thats when the guy saw all the black smoke. any ideas? plugs aren't black either.
Originally posted by larryriverside
i figured it out, but thanks anyway.
Well, post up. Don't waste space like this.
Need help with tuning my afc. 93 gsx 14b hacked honeycomb 550 injectors n-1 exhaust 12psi joe p boost controller. Running rich as #### right now need help
Hey iv had a surging idle problem for the last 3 or 4 months. Brought my car into many shops with no avail. i called the original owner and he asked me if the battery had been pulled and it occured to me that maybe when the clutch was replaced they pulled the battery. anyways he asked me what my s-afc settings were and i had no clue cause i know nothing about this stupid thing but i looked anyways....
looking @ the rest of you settings im drawing to the conclusion that mine are... very wrong =)
hear they are...
1994 Eagle Talon TSI AWD
Super – Air Flow Computer settings
December 24th 2003
1) Hi-Thr (HI)
1000
rpm
+ - 0%
2) Lo-Thr (LO)
1000
rpm
+ - 0%
3) Th-Point Lo – 10%
Hi – 50%
4) Ne-Point Ne1 – 1000rpm
Ne2 – 2000rpm
Ne3 – 3000rpm
Ne4 – 4000rpm
Ne5 – 5000rpm
Ne6 – 6000rpm
Ne7 – 7000rpm
Ne8 – 8000rpm
5) Dec-Air Thr - ****%
Ne1 – 10.0%
Ne2 – 10.0%
6) Sensor type: Karman
7) Car sel: Cyl = 6 Thr: arrow pointing up and 45 degrees to the left ( 1:30 )
8) Graph Scale: Pr: 760
Ne: 6000rpm
Cr: +- 3%
Sorry for the massive post but i really wanna get this solved.
can anyone tell me if this is wong and if so what should they be ? =)
thank you very much
Note: I do not have upgrade Injectors just upgraded turbo... not quite sure why this unit was installed in the first place. but no engin mods that would require this unit
Also: =) when im driving with the moniter on 4 channel the first reading on the airflow always reads zero.
i had my mass air flow sensor replaced but that did nothing
Originally posted by Green93TalonTSi
1st of all need to change those throttle % , it should be 30/70 and the 4cyl arrow up. that might help some , it would also help if u told us what ur mods are, cant help without knowing what u have done to the car.
hey help me out.. i have free flow cat/ muffler/ header/ venom/jetchip.. and aemv2.. and thats pretty much it.. what would be good settings for me??
not many mods... 16g turbo blow off valve magna flow exaust
nothing big.
and then that S-AFC computer...
this all came with the car
oh yeah and a centerforce duel friction clutch
yeah im looking into buying a logger.
and yes my fuel system is stock
im getting a logger in the new year
will any palm work
like the newer ones ?
safc settings.....please help.
I have a 1g laser awd
Ported and polished everything in the top end...turbo/new exhaust man/cyclone intake
3" turbo back with magnaflo high flow cat and OBX type-r muffler
big 16g turbo internal gate
550cc injectors
255 lph fp
fpr adjustable---what should the pressure be???
stock intercooler<---horrible getting fmic
1g mas no honeycombs screw out flush.
hallman boost controller
boost guage
blitz bov (atmosphere vent)....also have stock...i may put it back on.
new timing belt and other crap that goes with it
And----- i have a ecu chip.....thats set like this
rev limit change (7500 is stock)
ð 7500
X 7800
ð 8000
ð 8250
ð 8500
ð 8750
ð 9000
ð 9250
ð 9500
ð 9750
ð 10000
launch rpm - you can choose the clutchcut rpm separately below
ð 4000
ð 4500
X 5000
ð 5250
ð 5500
ð 5750
ð 6000
ð 6250
ð 6500
clutchcut rpm - this is the rev limit when the car is moving, but the clutch is in
ð 4000
ð 4500
ð 5000
ð 5250
ð 5500
ð 5750
X 6000
ð 6250
ð 6500
octane reset
X YES
ð NO
A/C cutout at 90% throttle for 3 seconds, although the percentage and the time are variable
ð 75%
ð 80%
ð 85%
X 90%
X 3 seconds
ð 4 seconds
ð 5 seconds
ð 6 seconds
ð 7 seconds
5) factory boost gauge can be changed to an O2 or knock sum gauge. The default knock sum is typically 5 per major division, starting at -7psi (-7=0, 0=5 knock sum, +7=10 knock sum, and +14=15knock sum
ð knock sum gauge
XO2 gauge
6) fuelcut removed
X YES
ð NO
7) YEAR of CAR
ð 90
X 91-92
ð 93-94
8) ORIGINAL EPROM
ð E742
x E931
ð EA01
ð OTHER (PLEASE EXPLAIN)
I had venom injectors 520cc ...and now 550 but the chip is set up for 520cc...
Any safc help will be greatly appreciated!!!
my car runs like crap after i did the head swap on my 2g...heres what i got and lets see who can help until i go to the dyno in a few weeks....
98 gsx
apexi 3 inch exhaust
injen intake
evo 3 16g ported with 34mm wastegate
accel wires with bpr7es
1g head
1g intake mani
1g TB
1g cams
cometic head gasket
IC pipes
10 psi for boost then it creeps to 20 or around there
act 2600
550s
255 pump rewire
s-afc
ported manifold and o2 housing
stock sidemount for now
egr stuff removed with blockoff plate
a bunch of maintenance BS
thanks
first off port the hell out of that O2 housing ... you shouldn't be creeping like that. Then basically the same settings someone with a 1g and your mods would have.
if i port my o2 anymore, the thing will crack!.....ive done many things to try and stop the creep but it wont work
i havent done that yet but ive thought about it......
my car will be put up anyways for winter in a week or two and im selling my turbo and going with another setup like ive wanted to..
I need help for my 90 GSX till my laptop gets working again,..
KN, 1g Mas lower honeycomb out, screw flushed,..3" air intake to turbo, 16G Evo, FMIC 2 1/2 pipe, UICP, 95 pistons/stock rods, no balance shafts, ported intake/exhaust Evo manifold, Stock downpipe for now (just got rebuilt), N1 exhaust, 190 Walbro, stock injectors (for now)
low point 30 Hi pt 80
any help?
Kevin
I need some base afc settings to get my car running good until I get a datalogger and wideband 02 to fine tune it. Here's my mods:
91 tsi awd
tdo5h 18g turbo ported and clipped
extreme mbc set @ 16psi
ported 2g manifold
Turbochargers.com FMIC 24x10x3 top to bottom
2.5" intercooler piping
Greddy TypeS bov
2.5" Buschur Racing turboback
test pipe
ported 1g O2 housing with dumptube
2g MAS
RC 550cc injectors
B&M Afpr set @ 43 psi w/o vacuum
Walbro 255lph fuel pump
Apexi AFC
KN,
16G Evo, MBC set at 15psi
FMIC
2 1/2 UICP,
no balance shafts,
190 Walbro, stock 450cc injectors (for now)
low point 30 Hi pt 70
ATTN 1G owners:
Is it true that lowering the Hi and Low pts can help out with part-throttle acceleration (ie, when you are cruising then get on the gas, "response" will get better?) And ithe following differs too if you have a hacked MAS or not.
This is done by looking at the O2 trim when you get on the gas. It states that if you get on the gas and the O2 trim goes low, that means Im too rich. I then should look at my rpm low settings compared to the high settings for each rpm point to see if they are higher. If they are, then I need to lower the high pt setting (from 70 to say 65) to run leaner. Optimal O2 trim should not be too full low or full high.
I read this on one of the S-AFC tuning links but would like to know at what "ratio" to lower the Hi and Low pts to,..For example, if I lower the Hi from 70 to 65, do I do the same ratio for low from 30 to 25?
Finally, for hacked MAS a 15% Low and 65% high was optimal for this guy,..
thanks for any help
Kevin
Fellow tuners:
It use to be so easy to tune, jets, timing, points dwell……. I just finished my 1999 Eclipse. Put a new short block because crank walk. So I installed a SAFC, an AFPR and an EGT in addition of the VPC. My initial settings are:
Low settings: 1k-2; 2k-4; 3k-6; 4k-10; 4.5k-10; 5k-10; 6k-10; 7k-10
High settings; 1k-21; 2k-23; 3k-24; 4k-23; 4.5k-23; 5k-22; 6k-21; 7k-18
TH Point: Low 30% High 80%
AFPR set at 43 w/out vacuum
The car started and was able to take it for a ride, not to hard (no WOT pulls) because of the new short block. Attached are a sample of some of the Ease OBDII recordings. I am aiming at learning how to tune so my question is:
After reviewing the recordings, Am I going in the right direction? And a silly one, Does anyone know what these means?
I think that the settings are a little rich, the motor started acting like too rich at the end of the run.
My mods are:
Big 16g ported, clipped 10degrees, Ported O2 sensor housing, Ported exhaust manifold, Lightly ported cylinder head, matched ports, 2.5od down pipe, 550cc injectors, ACT 2100 clutch, lightened flywheel, High flow cat converter, Walbro 255 in tank high pressure fuel pump, HKS sequential blow off valve, HKS electronic boost controller, Vtech plug wires, HKS high flow intake, K&N air filter, HKS 3" cat back exhaust, Twin Power DLI, HKS VPC, RMR sway bars, Stillen front mounted intercooler, SAFC, AEM big brakes front, Stainless braided brake lines, 2G Bolt on FPR, EGT, Chin spoiler, custom cold air box and duct, Front/rear tower brace.
Thanks, Lico
Frame 1 2.62
Emission Related DTC Count 0.00
Engine Coolant Temp 181.00 F
Fuel System 1 Status Clsd Loop
Fuel System 2 Status Unused
Intake Air Temp 66.00 F
Calculated Load 20.00 %
Long Term Fuel Trim B1 0.00 %
Air Flow Rate MAF Sensor 4.05 gm/s
Air Flow Rate MAF Sensor 0.54 lb/min
MIL Status MIL Off
O2 Sensor Out Volts B1/S1 0.10 V
Rich/Lean Status B1/S1 LEAN
O2 Sensor Out Volts B1/S2 0.02 V
Rich/Lean Status B1/S2 LEAN
Engine RPM 867.00 RPM
Short Term Fuel Trim B1 4.69 %
Short Term Fuel Trim B1/S1 0.00 %
Short Term Fuel Trim B1/S2 3.13 %
Ignition Timing Advance #1 Cyl 8.00 Deg
Absolute Throtle Position 0.00 %
Frame 3873 669.24
Engine Coolant Temp 205.00 F
Fuel System 1 Status Open Loop
Calculated Load 9.00 %
Air Flow Rate MAF Sensor 12.24 gm/s
Air Flow Rate MAF Sensor 1.62 lb/min
MIL Status MIL Off
O2 Sensor Out Volts B1/S1 0.98 V
Rich/Lean Status B1/S1 RICH
O2 Sensor Out Volts B1/S2 1.00 V
Rich/Lean Status B1/S2 RICH
Engine RPM 3523.00 RPM
Short Term Fuel Trim B1 0.00 %
Short Term Fuel Trim B1/S2 0.00 %
Ignition Timing Advance #1 Cyl 33.00 Deg
Absolute Throtle Position 8.20 %
Frame 4709 811.58
Engine Coolant Temp 203.00 F
Calculated Load 18.80 %
Air Flow Rate MAF Sensor 55.76 gm/s
Air Flow Rate MAF Sensor 7.38 lb/min
MIL Status MIL Off
O2 Sensor Out Volts B1/S1 0.78 V
O2 Sensor Out Volts B1/S2 0.92 V
Engine RPM 5016.00 RPM
Short Term Fuel Trim B1/S1 -1.56 %
Ignition Timing Advance #1 Cyl 28.00 Deg
Hey, just got a new fmic and im about to start tuning again.
My mods are:
sm 16g
190lph
550's
22"X9"X3" FMIC (2.5 inlet/outlet+ piping)
all hard ic piping
full 3" exhaust
ported exh man. and o2
1g TB + ported 2g int. manif. to match
boost @18psi
Anyone with similar mods done have any input?
man heres my setup but its screwy. i have a 90 tsiawd and i have a 2g mas with all honey combs out and other mods are in my profile. my ne points are 1k,2k,3k,4k,4.5k,5k,6k,7k. for throttle low at 30% high at 70% for
lo settings
1k +47%
2k +43%
3k +40%
4k +40%
4.5k +40%
im still kind of breaking in my engine so i haven't floored it yet but my 550 at idle is at low fuel trim of 114 and goes to 118. i am almost maxed out on the safc the a/f gauge seesm to be ok o2 voltage seems fine just my low fuel trim. then when im driving and i accel to anythin around 50% at any rpm i start knocking so i thought it was my high settings so i made my high setting similar to my low settings and it still knocks.... it knocks till i let go of gas. my mods will be changing by end of next week but for now i was curious on why my car is acting liek this.
safc help
550cc injectors
255 lph fp
boost guage
ð 7500
X 7800
ð 8000
ð 8250
ð 8500
ð 8750
ð 9000
ð 9250
ð 9500
ð 9750
ð 10000
ð 4000
ð 4500
X 5000
ð 5250
ð 5500
ð 5750
ð 6000
ð 6250
ð 6500
ð 4000
ð 4500
ð 5000
ð 5250
ð 5500
ð 5750
X 6000
ð 6250
ð 6500
octane reset
X YES
ð NO
ð 75%
ð 80%
ð 85%
X 90%
X 3 seconds
ð 4 seconds
ð 5 seconds
ð 6 seconds
ð 7 seconds
ð knock sum gauge
XO2 gauge
6) fuelcut removed
X YES
ð NO
7) YEAR of CAR
ð 90
X 91-92
ð 93-94
8) ORIGINAL EPROM
ð E742
x E931
ð EA01
Any help guys?
For all those looking to get information or settings...beware.
Example. Myself.
With all the mods i have, i should be able to run AT LEAST -15 across the board on my hi throttle side. My buddy and I did a datalogging run last night (NOSLO2PT0 on these forums) and guess what? Looking at the log, i needed at least straight *0* across the board pretty much to keep the knock count below 7. Every car is different.
I'd just hate for someone to use someone elses settings and blow the engine apart. I think its ok to reference eachothers settings...but some of you guys are looking for these settings to use on your own car. be careful.
hmm i lowerd my a/f settings did some wot pulls seemd like i was runign rich as hel at idle my exhaust still pops a little i was wodnering my o2 sensor reads nothing udner any accelaration eve under boost could it be a bad o2 sensor?
