Initial settings for S-AFC - everyone's opinion
i'm interested in knowing nate's settings as well.
I need to see if anyone has some tuning advise here is my setup as it is now and I need to know what are some good settings for the AFC:
Big16g
S-AFC
Profec B
Greddy 660cc Injectors
Walboro 255hp Pump
Apexi TT (For O2 Voltage)
2-3/4" Cat Back
3" Test Pipe
Lower ICP
HKS SSQ Bov
K&N type intake
Exedy Clutch
and more.....
Anyone with similar setups? Please advise... right now I am tuned for .96-1.04 O2's... to rich?
hi, i'm about to mount my SAFC this are my mods...
Big16g@18psi on 93oct
550's
190walbro
stock i/c
honeycombs removed
thanx!
i could use some help myself....I just installed my safc today with my lp fuel pump and 550cc injectors. I have no idea where to set it, so of course I'm runnin so rich right now. it was emabarrising to drive home from the garage. I couldn't do anymore than 30, and my car was sputtering......:cry:
Originally posted by TURBOSPYDER
So at Idle your low setting is at -35 all the way to 7000rpms? Whats your fuel pressure set at? What EGTs do you get?
Thanks.
Yeap...My fuel pressure is at 45psi and EGT's goes up to 1500 at WOT...but, if I'm driving normal...it's around 1000-1300...
Here are my starting settings until I get hooked up to a wideband.
AGP T28
Walbro 255
RC 550's
VP FMIC
93 Octane
16PSI
High
1000-2000.....-20
3000.............-16
4000-8000.....-18
Low
1000............-3
2000............-4
3000-4000....-6
5000............-3
6000-7000....-2
8000............-3
Like I said they will change once the wideband tunes it and I increase the boost to 20+!
:D
Super 20g
Warlboro 255iph pump
Stock rail to 625cc injectors
AEM fp/regulator
3'' piping out
Combes all out, screw turned etc.
AFC settings;
Lo-hi settings 30-80
LO.
1000 -2
1500 -2
2000 -3
3000 -3
4000 -4
5000 -5
6000 -5
7000 -5
8000 -5
Hi.
1000 -18
1500 -15
2000 -15
3000 -18
4000 -23
5000 -23
6000 -23
7000 -23
8000 -23
Ect;
Pr: 1.okg/Cm2
Cr.+-15%
The car runs good, but still at WOT I peg the green light down rich. This is pretty close tuning for me. I plan to use my new EGT guage with settings other than the above to see if I can find a sweeter spot.
Also remember Im tuning other than sea level, Im in Colorado Springs, Colorado, the altitude is different than other AFC set ups. Im sure if any one uses this set up at different altitude it should be close enough to let you fine tune for your own set up. Good luck
You guys think you have it so bad. Try not being able to find anything like this about the car you drive. I have a 89 Plymouth Colt and no one and I mean no one has been able to help me set up my car. Here is my setup.
4g61 (1.6l turbo) for those who didn't know.
'90 DSM cams
16G with 6CM exhaust housing
ported 2G manifold and 2G o2 housing
2.5" exhaust
High-flow Cat, Race Magnum muffler
660 CC DENSO injectors
1G DSM MAS
stock 1.6 ECU
1G FWD flywheel with AWD plate and kevlar disk
Stock DSM sidemount
Stock fuel pump, not rewired (yet)
Running 15 to 19psi on pump gas.
Safc Initial settings HELP!!!!
Does anyone know some safe settings for an SAFC on a 1g 14b free mods + ported turbo and o2 sensor housing? I want to hook this up but I don't want to blow the motor getting it to a tuner. a little more detail of mods.....1g mas lower honeycombs taken out, MBC only pushing 10 psi for now . Boost gauge, pocket logger.
I'm building a uicp 2.5"
'90 DSM cams
2.5" exhaust
1G DSM MAS
stock 1.6 ECU
Stock DSM sidemount
There are a couple of them here in the Tampa area that are running them. Try
www.tamparacing.com
our regular BB is down right now.
but when you go to tamparacing.com go to mitsubishi maybe you can get to them
anyone have settings for 720cc
t04 mutt turbo
255 intank pump
aem cam gears
3in dp
what is your Hi setting on 22 pounds of boost ,Im from Reno altitude somewhere around 4500 ,I have the same turbo and injectors.
Originally posted by 20gst
:D
Super 20g
AEM fp/regulator
3'' piping out
AFC settings;
LO.
1000 -2
1500 -2
2000 -3
3000 -3
4000 -4
5000 -5
6000 -5
7000 -5
8000 -5
Hi.
1000 -18
1500 -15
2000 -15
3000 -18
4000 -23
5000 -23
6000 -23
7000 -23
8000 -23
Ect;
Pr: 1.okg/Cm2
Cr.+-15%
Wow! Thanks man. I must of been ignorant not to try moving up my low throttle point. I just took your advice and I'm stunned with the SOTP difference. Smooth low end torque. YESS!
i just instaled my afc all i didnt not even touch anythiny yet.....my set up is
big 16g ported &clipped
450's
walbro 255
stockintercooler
my in-1 in reading .150 .....i heard that that they should be around .800V
what could be the reason why my volts are so low
only thing i could think of is bad o2 sensor......any help will be useful....thank you
well its not a choice but i can give some info. i have a 19c, stock mas, 550's, walbro 255, afc2. my settings are:
th point :low-30% and high -70%
low throttle dont seem to mean much to me, i just made the autometer gauge sit on lean and went up 2% from there so it references back and forth.
my high settings are negative 18 until 3k when full boost hits then i have negative 14 so it has a little more fuel from 3k to 4k. then the rest are all negative 20%.
on these settings i ran a 12.7 on pump gas on 18" rims at 24 psi so i think it works pretty well. my egt's only hit 1600f when i'm on the highway in 4th and 5th gear doin over 110 mph. i'll have dsmlink soon so i can check knock and control timing
t-25 basic bolts ons, stock injectors
tuned with a pocketlogger
20% LT
60% HT
LT- 0 across the board
HT
1K 2K 3K 4K 5K 6K 7K
0% 0% -1% - 1% -3% -3% 0%
3rd gear run everything is .92v on the pocketlogger. Still running a little rich in 2nd gear.
If you are planning on upgrading, BUY A POCKET LOGGER! Other than "free" mods, you need one. I don't care what you think or say. Don't whine that you don't have the money for one. If you can't afford the logger, you sure as hell should upgrade. Got it? Good.
2G
small 16G
550's
190 FP
3" O2 elim/cat back
ported turbo/manifold
Low
-10 across
Hi
-13 across
With this I am getting .98V @WOT and no timing retard.
ETE32.
DSM-Peformance 3" Intake Pipe.
Apexi Power Intake.
Apexi FMIC Sylvia Core.
2.5" UICP.
HKS SSQV
650cc Injectors.
Walbro 255 HP Fuel Pump.
ACT 2600.
Fluidyne Radiator.
NGK BPR7ES Plugs & Wires.
All ARP Hardware.
Ported Exhaust Manifold.
3" O2 Housing W/O2 Dump.
3" DP-->3" Test Pipe-->3" Dynomax Cat Back Exhaust.
Apexi SAFC.
HKS EVC IV BC.
Palm M100 PDA/DataLogger.
Greddy EGT Gauge.
Blitz BL Series Boost Gauge.
Anyone with this kind of setup or similar please help a brotha out.
heres mine:
190lph walbro
safc
550's
sm 16g
ported turbo,manny, and o2
full turbo-back 3' exh.
injen intake
hks bov
full IC piping
profec b set @ 17psi
LOW
-2 -4 -5 -7 -7 -7 -7 -7
HIGH
-11 -11 -11 -11 -10 -11 -11 -11
Im still tuning it out, but im sure that I can lean out the highs a little more. (my loggers screen took a crap on me, so i cant tune untill the new screen comes in)
Originally posted by Airpoppoff
id like to know more on the t-28 with 550s setup if anyone else could help me out...
so would i thats my set up i ran aprox low -5 across and aprox high -25 across and it runs good but i have not logger to test anything i also put in a msd dis2 at the same time and im ting to tune the 2 to work great together if ne one has some tips on that set up let me know
xscacsx@aim
I just bought the APEX'i S-AFC 2, i am really impressed with all what it has to offer. I'm not going to mention all my mods, but i have the 16G, with stock 450's, smic, and holley 190lph fuel pump. I had the thing at High setting -10 all across the board from 5 to 7 thou rpm. But i wanted to smooth it out, so i started leaning it out at 2800 rpm right where it starts to get into boost, going from -1 all the way to -9 at 7000 rpm, i am not getting any knock on AFC 2 as it shows. and then low i have it running rich at 2800 by +1 and then goin up to +3 then falling off to -5 by 7000 rpm, and the HI and lo settings at 30 and 60.. Hey it works ok for me, i am going to tune it on the dyno here soon... As for now i wil be getting my 550 injectors next week, and the stcopk ones are whinning at 6500 rpm and higher....:thumb: hope that helps some...
I probably wont be able to reply to this for awhile, i am on a computer in a public library i don't have one at my house i moved into in lexington yet...
I have a question, i know this thread may be a bit old, but please bare withme and if you can give me your opinion. Does the temp have a major impact in the fuel trims and running decently rich and richerrrr. I tune the lo settings using a datalogger and well my car seems to need a lot more gas than when i tune the lo settings at night. Also the car for exmaple today it rained like a mo fo down here in Miam and the car seemed to be running all the sudden richh!!! Like i bogged every know and then under accelaration. Any comments or ideas. Humidity and the temp of the day has a big impact on tuning and fuel trims?? Thanks
