steve
DSM Wiseman
- 17,380
- 4,045
- Feb 3, 2002
St. Charles,
Illinois
The stock maps actually drop to about 9.5:1 at WOT. Tuning to hit about 11:1 AFR is typical.
If you are still at 15psi, I would go ahead and bump that up to about 17 or 18psi and make another pull. I suspect everything will be fine since you're running a -22% correction factor on 650cc injectors.
Here's a pull at 18psi. Airflow is still a little disapointing. Wideband is still pegged at 10.0. And how can I fix that 3* of timing? A little low isn't it?
Time...........RPM......Timing.......Airflow.........TPS
0.4........... 2220.0...... 30.0......... 0.78......... 58.94
0.8........... 2264.0...... 23.0......... 3.53......... 98.62
1.19......... 2364.0...... 24.0......... 3.82......... 98.62
1.58......... 2468.0...... 24.0......... 4.24......... 98.62
2.51......... 2752.0...... 23.0......... 4.79......... 98.62
2.92......... 2904.0...... 19.0......... 6.71......... 98.62
3.31......... 3044.0...... 15.0......... 7.8........... 98.62
3.72......... 3220.0...... 10.0......... 9.69......... 98.62
4.11......... 3408.0...... 8.0........... 12.48....... 98.62
4.77......... 3816.0...... 5.0........... 14.71....... 98.62------] Is Timing
5.17......... 4020.0...... 3.0........... 15.86....... 98.62------] a little low here?
5.84......... 4360.0...... 9.0........... 16.34....... 98.62
6.24......... 4596.0...... 9.0........... 18.33....... 98.62
6.64......... 4812.0...... 9.0........... 19.17....... 98.62
7.03......... 5032.0...... 9.0........... 20.51....... 98.62
7.44......... 5216.0...... 10.0......... 21.45....... 98.62
7.83......... 5416.0...... 11.0......... 21.95....... 98.62
8.23......... 5636.0...... 14.0......... 21.77....... 98.62
8.63......... 5832.0...... 15.0......... 22.33....... 98.62
9.02......... 6000.0...... 16.0......... 22.5......... 98.62
9.43......... 6192.0...... 17.0......... 22.9......... 98.62
9.83......... 6356.0...... 17.0......... 23.65....... 98.62
10.22....... 6508.0...... 17.0......... 23.79....... 98.62
10.89....... 6784.0...... 19.0......... 23.89....... 98.62
Yeah, your timing is low in that area. Target timing at that airflow is 7 degrees provided coolant temp is below 206 degrees and IAT is < 84 degrees. Max airflow during the run hits 1.59g/rev at 6784rpm. Target timing at that point is 22 degrees, so it's very possible you're knocking.
But, keep in mind that base correction for 650cc injectors is -31% to hit the target AFR of 9.5:1. Based on your correction factors, you're about 9% richer than that and probably hitting an AFR of about 8.6:1. That's rich knock area. Personally, I would lean it out about 5 or 6% and make another pull.
You might also want to pull your plugs and make sure they aren't fouled because of running so rich. Did you go one step colder on the plugs?
Great thread guys. Lots of useful info. I'm learning alot
You have a Wideband right?
It shouldn't take more than a few pulls to get the AFR set by just watching the Wideband...
I do. But what AFR should I tune for? 11.1?
It might also be a good idea to wire the WB into the ECU so you can log the Lambda value. That will make a good addition to the logs.
