Initial settings for S-AFC - everyone's opinion
I have a walbro 255HP fuel pump, FIC 650cc injectors, soon to come aeromotive fuel pressure regulator and S-AFC2. It has the stock 14b turbo. I am at my very begining with tuning and could use some base settings to go with. If anyone knows of some good start settings I could use I would appreciate the help. Feel free to email me at [email protected].
This thread would be a lot more helpful if people just posted their settings and that's it. No pointless posts or people asking if anyone has their setup and if they could post their settings ... if they wanted to post them they would have already done it. Someone please clean up this thread and only leave useful posts .. not posts of people asking what their settings should be. :thumbdown
There aren't any. Anything useful is in the FAQs or on your loggers.
alright guys i def need some help here
Last night i installed 680 pte injectors and my car wont idle and if does drops to 100 rpm and rises slowly these are my mods can someone give me some settings so i can tell my friend to tune it for me i have nothing to log with so some ok settings would be appreciated.
97 Mitsubishi Eclipse GSX 5 spd
Intake
T3/T4 60-1 with Tubular Exhaust Manifold downpipe, 3 inch Turboback exhaust system with 3 inch high flow cat
Greddy Type S BOV
Upper Intercooler Piping, Lower
FMIC
680pte injectors
walbro 255lph high pressure fuel pump
SAFC2
Road Race built transmission
Centerforce Clutch
Lightened Flywheel
stock internals
can someone plz give me some settings so my car will atleast stay on at start and coming to a stop... this happened after the last night when i installed the injectors ive never touched the safc2 before... so its just installed... thanks guys
Hey guys...i read all 7 pages to try to find a similar setup to find settings but i couldnt so here are my mods; any help will be greatly appreciated.
1998 tsi awd
3 inch turbo back no cat
ported 2g manifold
ported 14b including 02 housing
Stock injectors
255 high pressure fuel pump
tuning with the afc2
I jus want somebody's advice and a good settign untill my pocketlogger is here.
thanx alot
peace
1998 tsi awd
ported 2g manifold
Stock injectors
thanx alot
peace
Leave them zeroed out ... you have no need to make any adjustments really.
ummm. The car was backfiring so it was runnin really rich so i backed it out til it no longer backfires so its not as rich but i guess ill wait til i get a pocketlogger but leaving it at zero is DEFINITALY not the right setign for my setup :thumb:
why do you have a pump that big on stock injectors? I guess give -5 across a try, but chances are you are going to run into problems with that stock fpr overrunning with that pump.
Depending on if you hooked the second input wire on the safc into your O2 sensor 1 you can go to sensor check and just floor your car and read the middle numbers. Keep adjusting the safc till it says roughly .92 v. Keep in mind this is not the way to do this, but generally you should have a logger first and then upgrade fuel stuff. Your low settings you'll have to do by feel and sound for now but redo them as soon as the logger comes.
i dont have a fuel pressure regulator because i cant afford one right now but its next. I have a 255 because i bought it off a friend for like 30 bux only 2 months old.
BTW, having the correct fuel pressure is imperative to making correct tuning decisions. I just realized that my afpr was set to 33psi, not 43 like the stock setting. It's no wonder my safc values were so far off from everyone else's. "Why does it still want more fuel!?"
I have the following mods:
Big28 ported and polished
Ported stock 2G manifold
Ported 02 housing
Full 2 1/2" Crush bent Turbo Back, NO CAT, rear 02 retained
FIC 650's
190 FP
Homemade UICP with 1g BOV w/Dodgemod Modification & its recirc'd
procarparts air filter
Stock SMIC
BR7ES NGK Copper plugs
Hallman MBC
Homemade LICP
2 1/4" Turbo inlet pipe
Everything else STOCK, Cams, Gears, wheels, tires, Internals, Belts, Battery.
FULLWEIGHT with a tank of pump gas 3280 lbs.
Best pass : 13.2 @ 104 1/4, Best 60' 1.79 60', Best 1/8th 8.3 @ 82 mph
My thr settings are 30/70
NE points 1k,2k,3k,3.5K,4k,5k,6k,7k
Lo settings:-28, -32,-33,-34,-34,-34,-34,-35
HI settings:-34,-34,-34,-39,-38,-36,-36,-36
Based on www.taboospeedshop.com's HP calculator, check it yourself
http://www.taboospeedshop.com/calculators.htm
288 at the wheels, 348 at the crank.
I used RRE as a general set-up, and seat of the pants tuned the rest.
No datalogger, No Wideband, No EGT.
But I am just a Dumba**.
Wait till I get a FMIC and a real clutch.
I anticipate Deep 12's.
Good luck.
Gsxtacy
I am running a t3/t4 setup with 550's and my car is still running pretty lean. i used the rre settings to start seeing as how they had the same prob but would like to know if anyone has any better one's to fit my setup more specificly. its a 1g tsi. thanks also i do some times get idle surge when the engine gets past the half way point on the water temp gauge.
t3/t4 57 trim
cast mani
550's
2g maf
hks intake with hard pipe
fmic
greddy sp1 exhaust
2 1/2 downpipe with cat
findanzaa fly
act 2600
tial 35mm gate
safc
electronic boost controller
type s bov
ngk7's
msd dis-2
Hi,
The car is a 95 Mitsubishi Eclipse GSX. With a FP big T28 turbo upgrade. My modifications are: FP 17PSI actuator, Manual boost controller, Injen intake, Greddy Upper intercooler pipe and type S BOV, Ported EVO III O2 sensor housing and exhaust manifold, Apex'I GT downpipe and catback, AEM AFPR with B&M gauge, Walbro 255 lph HP fuel pump, FIC 550cc injectors, Aeromotive 10 micro Fuel filter,
-6an Stainless steel braided fuel lines, MSD 8.5 mm spark plug wires, Autometer gauges, S-AFC, fuel pump is rewired, battery relocated and a few more things.
The conditions were 80 deg F (6-7PM), dry weather, 92 octane and boost level of 15 PSI that slowly raises to 17 PSI and 40 PSI fuel pressure.
These are the S-AFC settings:
Low 30% and High 80%
1000 2000 3000 4000 4500 5000 6000 7000
+1 -1 -2 -4 -4 -4 -4 -4 Low
-11 -13 -17 -25 -26 -27 -33 -33 High
The log made with a pocketlogger:
RPM----Timing---O2 #1
2324------17------0.90
3060------14------0.92
4028------11------0.92
4584------13------0.94
4980------13------0.94
5072------11------0.94
6064------15------0.94
7032------16------0.96
If this might be to anyone's help!
Sincerely
Sven
Can someone give me a base setting for my safc2
im scared to put it on my car with out setting and im having a hard time learning this stuff
I have my honeycombs remvoed- s16g ported-web cams-255 fp-2.5 down pipe-3 inch ex-stock injectors-underdrive pully-front mount intercoller-hks ssbov-few other small thing
can anybody help me plz
-3" intake 2g mas (1g car), one side honeycomb removed :( (previous owner of the mas)
-2.5" exhaust o2 housing back, no cat.
-boost: 10psi creaping fast to 19psi
-stock 450cc injectors, stock fuel pressure, stock pump (rewired)
-stock pipes, stock side mount with duct tape covering pin holes :)
-leaky tb shaft seal, and no other boost/vac leaks
-stock turbo (14b) and manifold (1g) unported.
low thr: +18% @ 1000rpm, +17% @ 1800 rpm, and then a faster decrease to +6% around 3000rpm.
high thr: +7% up to 3000rpm, +13% @ 4000 and so on, ending with 18% @ 7000rpm.
max d/c i've seen with this setup was 106%
3rd & 4th gear pulls on a cool even i was at 93% at the last WOT rpms.
i get awesome timing, obviously if the knock is low. don't reccomend boosting much during the hot day traffic.
dnsyang said:
FP Green turbo
720cc injectors (Sieman deka)
Walbro 255 lph fuel pump
Hi- 42 across
Low- 35 across
I have a 92 talon PTE-T66-T4,Denso 720's(also have 1000cc's),Aeromotive ex-ternal pump,race front mount
anyway,the motor is built,I just spent $8,900 on internals,and bolt-ons,only thing I dont have is a fuel cpu,or a ems.I plan on buying a haltech,but for now can i run an AFC.I've been told that with 720's(let alone 1000cc's) it's gonna be tricky.and at the least i'll have to get a MAF off a 2G.Is this at all possible to use the afc and still get good performance,or will it be a waste of time? :laser: :talon: :dsm:
ok..heres what i have, and my problem....any help is great
1G talon 6 bolt
stock internals
16G turbo
550 CC injectors
3 inch MAF w. translator V.2.10
AFC
i tried setting the MAFT to zeroed out, and tried to tune with AFC, but it still idles like crap, between 900-1500 rpms fluctuating, sometimes stalling. also, my readings on my AFC for my O2 are really low at idle, .000 to .015. nothin on my A/F gauge unless i give it some throttle. any help would be great. i did search, nothing really with the same problem using the MAFT. thanks
Ron
450's soon 560's (evo for little money :D) evo 3, 16g turbo, honeycombs removed, 255 walbro, b&m fpr, 3"catback no cat, stock smic, 17psi
I will go and get it tuned with my friends wideband soon, i just wanne see how good you guys are :D
