Initial settings for S-AFC - everyone's opinion
2g, evo3b16g 15psi, 780's, fmic, 255, fpr, exhaust, built bottom end.
i need some base SAFC settings for a 91 talon tsi awd
2g MAS
Prescision 50trim at 15-20 psi
660cc injectors with a 255 pump
3'' exhaust
fuel press. reg. set at 37psi
im not sure what other info is needed were nto to sure of the tuning, but if anyone can give us some base settings it would be appreciated. also is venting the BOV a good odea with this set up and are there settings for that
2g MAS
3'' exhaust
Im putting this same setup on my car, but I also have comp cams 101200's and I would like an answer to this as well.
ok i have a ?. i have the afac and the afac boost controler. should i run them both off the ecu or. can i tap rite in to the other safc harnnes to the ecu. so one goes to the euc that i had and the other goes to nothing shoul di run it to the ecu again?
