Please Support Rix Racing
norice4me's Eclipse GSX
Mitsubishi Eclipse GSX
and the new bad ass 2.3
custom down pipe
2.5" Test pipe
magnaflow 3.0" cat back
Ported '95 Exhaust Manifold
Ported O2 housing
50 trim
mas translator
APEXi Super AFC
Walbro 255HP Fuel Pump
ACT 2600lb Xtreme Clutch
DOG BOX TRANNY
K&N Filter
hks boost controller
Turbotrix 2.5" upper intercooler pipe
Turbotrix 2" lower intercooler pipe
Unorthodox underdrive pulley
880cc injecters
tial wastgate
tial b.o.v
Mods-Engine
Modified Stroker block (6 bolt crank platform)
Fully CRYOED block, crank, rods, and pistons
Custom Wiseco Pistons (8.8:1 ratio/.020 overbore)
Scat Rods
ARP main studs
All new freeze plugs
Balance shaft removal kit installation
New oil pump front cover
New oil drive gears
New 6 bolt oil pan with SS bolts
Line hone, torque plate boring, decking, and plateau honing of block
Assembly of shortblock
Balancing and blueprinting of rotating assembly
File fit rings
All new Clevite bearings
Rear crank seal plate with new seal
Dipstick tube
Level 1.5 CRYO processed head (1mm over SS valves)
New big bore lifters
Crower spring kit
FFWD DKS2 Cams
ARP Head Studs
Mitsu MLS gasket
Fidanza adjustable cam gears
Dunlop SP8000 Tire (225/50/16)
Konig rims
Eibach springs
KYB agx struts
Parts Wishlist
gt40r commin real soon
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
Dyno Session Details
Fuel Used : Pump gas
Turbo : rs49
norice4me
More in 1G DSM
Share this Vehicle
