increase vacuum
madoc05
May 1, 2005
Canandaigua, New York
To start off at idle my vacuum is reading 20in. and when I go WOT I have about 4in. By 4000 I’m at 5in. and at 5000 i have about 10in. The car seems to be sluggish any ideas what could be causing it?
Sounds like you're moving too much air in idle... You should be at about 15 in. idle and next to zero at WOT.
I don't know exactly how this correlates to your car feeling sluggish though. You'll have to give us more symptoms.
there isn't any other symptoms it is gaining vacuum with rpm's and the engine fells bogged it seems to have trouble gaining Rpm's and speed.
Have you checked for leaks, cracks, etc.? How's your air filter? Has it been changed or checked any time recently?
Open the hood of your car and just stare - this sounds like it may be something obvious. Just look around for out of place things and report back.
I checked all the lines coming off the TB and manifold all seem to be good. As for the air filter that was changed when i did a tune up in January.
...find your vacuum leak
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
