usmc0651dns
- 209
- 1
- Jun 3, 2010
Monticello,
Kentucky
Since I bought my 97 GSX about a week ago, it has been nothing but headaches. I changed the plugs and wires. I cleaned the MAS. I took out the 880cc injectors and replaced them with 660cc. The car has a Greddy 18g kit. The car has never boosted past 5 - 10 PSI. I tried doing a boost leak test and it sounded like air was leaking out where the throttle body and intake manifold meet. I tightened the screws there and it still isn't exactly right. I used ECMLink to set the injector settings appropriately. I also tried to get the MAF settings to a desirable level. I was feeling good about all my hard work so I went out for a cruise to test the tune. I was in 3rd and the car was actually holding boost. I went WOT and the boost hit about 12 PSI and then something happened. The car wouldn't make any power in any gear. The car builds absolutely 0 boost. It won't idle unless you keep the gas pedal held in. On Link the RPMs show up fine but in the car itself they never go over 3000. I don't see how the car gauges see a different RPM then Link but I'm totally bummed out and don't even know where to start again. Please help if you have any idea what might be going wrong now.
