SnoopySLR
20+ Year Contributor
- 1,158
- 4
- Nov 14, 2002
Highland,
Michigan
Well guys..I still can't get it running. Here is the story.. .please help me!
Timing belt snaps, so I pull the head and put it back together. Now she doesn't want to fire up. I found that 1 & 4 are not firing. First thought, plugs...then wires. Both are good. Then I thought Coil (I've been working from the plug back to the start of the signal). The coil is working perfect. The wire from the ECU to the coil is ok... not shorted out or grounded. The ECU itself is not sending any signal out... so I figured maybe my ECU is bad. I got another one from another DSM'er. The ECU didn't change anything when I swapped.
So now I'm stuck to figure out whats next. I'm 90% sure that the crank and cam pos sensors are good... because coil 2 is getting signal and firing 2 & 3 plugs.
If anyone has any other ideas I'm all ears. Also, if anyone has the wiring diagrams for our cars, I'd like to know what else is involved in our ignition system...
