Igniton fuse blew and keeps blowin
Arsenic20
Mar 18, 2008
Ofallon, Missouri
1990 talon awd
I recently took out my clutch pedal out to repair it and put it back together and I was driving and it blew the ignition fuse. So I ran some diagnosing on it and found that I can take my radio fuse out and I cant use my heater and the powered windows and my flip up headlights fuse was out too ( I had used those to replace the ignition fuse to get home) and the car will run and not blow the igntion fuse. Well I went to replace the 30amp fuse for my windows and had the car running and not knowing I couldnt use them either the ignition fuse was getting hot and the wiring was getting hot so I ran around and turned the car off and by that time it was smoking right behind the ignition and the car actually died. Now the car will start and idle for about 10 sec and then shut itself off. It seems to me like it just turns itself off like a bad ignition or something. any help would be greatly appreciated.
