Fuse Keeps Blowing
xdannyx25
Sep 29, 2002
I had to take out the lights in the rear to but on a new bumper. Now when i connect the passenger side white connector to the brake lights then turn on the head lights the fuse blows. I can connect the black one that goes on the very corner end of the light but not the white one. Im using the right fuse even tried a 20 which is 5 more, still blows. When it breaks the turn signal one under the dash breaks also.
something is wired up wrong and you are shorting straight to ground and that is what is popping your fuse every time. Double check the wiring and connections.
i have and made sure none of the wires are touching. i put electrical tap on the wires that had crinks in them and it still blows :confused:
