idles high
*Sigh*
Have you adjusted your biss?
2700 is a bit too high, about 700 too high.
Is your throttle cable sticking?
Did you test your ISC between the pins?
Is your throttle plate hanging up on anything?
Like said above the ISC and/or BIss screw out of adjustment also the throttle plate hanging up
could be the FIAV or a Vacum leak also, the throttle linkage not adjusted right more likely the first few though
