identify please
RocCitySlayer
792
7
Nov 20, 2011
Rochester, New York
Can anybody tell me what this is? it was on my car when I bought it. What is it used for? Its obviously plugged into something but there was no vac line to it (The black thing on the firewall)
That is a GM map sensor. Used for either Speed Density or for a electronic boost gauge or just to log with
There should be some numbers on it. Post them up that way we can tell you what kind it is. As there are a few the GM makes
I dont have speed density, my Greddy boost gauge is ran off the fpr, and i wouldnt know how to use it to log anything... So is it pretty much (in my case) just there incase I ever need it?
It could be there for looks. Try to trace the wiring out and see where it goes. It may be spliced into ## MAF sensor harness or it may have been installed just never put to use. But if ## car runs just fine its there if you need it or not you could remove and put up for sale
Just went outside to check and there are no numbers. There is just a very small upside down 4 under the nipple a vac line would go on
The wires look kinda like they run behind the cam angle sensor
They should be on the side that is facing down I believe or on the backside against the firewall. I cant remember where exactly they are. But they should be there.
