ECMlink IDC goes to 0
97EagleAwd
5+ Year Contributor
48
28
May 9, 2021
Jacksonville, North Carolina
So new issue started the other day out of nowhere. I dont recall making any changes before the issue started. Every time you go WOT the IDC goes to 0 and the car dies. TPS seems to be functioning. Maybe I am overthinking/missing something. Any Ideas? TIA
I think the root cause is because your ECU is seeing KeyStart on all the time. That combined with 100% TPS input tells DSMLink to cut off the injectors so you can clear a flooded condition. KeyStart should only be on while you are cranking. Check pin 71 to make sure it's not always seeing 12v.
