IAC problem?
doobie1121
Jan 22, 2004
Arizona city, Arizona
I have a 97 gst and it has been ideling really low when i come up to a stop. It almost dies some times and other time it runs just fine. It just started doing this like a week ago right after it had been broken into and stole all my stereo equipment. :mad: I cleaned my throttle body and air filter and it helped some. Also there is a ticking noise coming from the sensor on the bottm side of the TB. I think it is the IAC sensor. It happens if i just turn the key to the acc position right befor i start it. Well any help would be great so thanx in advance.
i dont know, but your symptoms are alot like mine. car sounds like its misfiring, idles really low and wants to die sometimes. i reset the iac by turning the key on the on position but not starting the car, unplugging the sensor wire then plugging it back in. it idles at a constant 650-750 now so i can live with that. but i might just buy a new iac. also if i turn on the ac it wants to die, it drops to 300 rpm's. try resetting it and see what happens. also you can test it by taking a digital voltmeter and test the resistance between the 1-2, 2-3, 4-5, 5-6 prongs. they should read between 28-33ohms, mine were 31 so im stumped. btw when you take of the clip it looks like this......
1 2 3
4 5 6
and remember, youre testing the actual sensor, not the wiring. have fun. take out the battery too its a whole lot easier.
