iac circuit problem
boost lg
Oct 20, 2008
brooklyn, New York
hey guys i posted a thread about this but couldnt really get any answers expet one guy zak and thank you zak.
i recently had the battery terminal touch the hood of the car causing the car to die and the terminal got melted,
i replaced the terminal and used my other battery.. After doin that i turned car on and my idle was jumping up and down breathing in and out from 2000 to 1500.. i couldnt figure it out so my friends dad is a mechanic and he brought his snap on ecu comptuer ob2 scanner..
the scanner was reading that the iac circuit is bad the computer was showing something is not right with the iac circuit...
he said i need to replace the ecu cause the circuit is in the ecu.. i can still drive car but the idle is always high car moves but itself and it hard on the tranny when i brake and im almost stopped the trany shifts hard you can feel it like a mini thump would should i do please help/
i tried replacing iac nothing its def circuit related
