I have got two 98 Eclipse GST problems!!
tvdurst6407
Mar 30, 2008
New Philadelphia, Ohio
Ok so the first problem I have is only after I boost a grayish white smoke pours out of the tailpipe and stops after a minute i am assuming its valve seals but is the anything else it could be ? And the other problem is my tach wont read at all it just all of a sudden stopped its factory so i am not sure of where it is hook up under the hood to see if it is disconnected or what if anyone can help would appreciate it.
How much psi are you boosting? It could be excessive crankcase pressure. If you have the stock PCV valve in place it can't really hold back over 10 psi. You can actually blow thru a new Mitsu PCV valve with your mouth. And we are supposedly only able to blow like 4 psi or something. Anyway, I put a check valve inline b/w my intake and pcv to stop boost from pressurizing my valvecover and my smoking issues stopped. Liquid/Gas Check Valves - US Plastic Corporation
oh and its only getting round 8 or 9 I have it turned down never had it boosting anymore than that
It doesn't do it in boost at all only after i start to slow back down it just unleashes the smoke like crazy
the turbo is new so im not to sure it has any problems im just guessing oil is seeping through the valve seals. so i am think of just tearing the head down and restoring it. Any suggestions on the tach not working ?
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
