2G I can’t figure out the problem with my 97 eclipse I’ve tried everything
Eclipse gs spyder
Jul 19, 2022
Belmont, New York
I have a 97 eclipse gs spider when I start the car it run great but as soon as you press the gas for the remainder of the time the car is running it runs extremely rich and every sensor in the car like dies so to speak like the coolant temperature sensor reads -40 mass airflow sensor doesn’t read both 02 sensor don’t read anything the tps reads 100% im very confused I’ve replaced the coolant temp sensor the map sensor both 02 sensors tps sensors the tps sensor I’ve asked multiple people brought it to multiple people and I can’t figure it out any ideas?
Check the GROUNDS for the car. Make sure you have one going to the engine, the firewall, the fender etc. Most of the sensors run on a "sensor ground" at the ECU and 5 volts out from it. It could be as simple as a wire not making a connection at the computer or a "gremlin" chewed a wire into two. A lot of folks over look good grounds to everything is why I brought it up.
Sensor ground is pin 92.
I am a 1g guy, but this pin out diagram should be helpful
