6bolt swap with 97-99 adapter harness in 95 eclipse problems
loco4G63
147
Jan 26, 2003
Fredericksburg, Virginia
Ok guys here is the issue I received a 97-99 adapter harness for my 95 eclipse which i already got running with black top 1g CAS and DSM-Link V3. I installed the 97-99 cas adapter harness in my 95 and soldered the blue wire. I also clicked the box for detecting misfire in my DSM Link. I adjusted the timing as well and after all this my car still wont pass 3k rpm without misfiring. Is the cause because of the harness? I ordered the correct wire harness and was sent the 97-99 and I just went for it. I contacted MAperformance and they are going to send me the correct harness in exchange for the 97-99 unit I installed. Will this fix the issue? I also wanted to know do I have to swap around any wires in my harness or is simply clicking the CAS box invert as well as checking for misfires boxes sufficient? Thanks in advance I just want to actually hit above 3k and maybe one day see how a little boost in my life would feel.:confused:
