Zurc503
- 1
- Aug 1, 2026
Salem,
Oregon
Keep it simple do all the other suggestions first, Good luckI plugged in a spark plug tester to all cylinders according to the packaging instructions it indicates a fault with the fuel as I tested them
It has to have some sort of tuning capabilities. Figure out what it is. Possibility ECMLink. I'd suggest to pull the neg battery cable off the battery, then remove the ECU from below the radio. Open it up and see what's on the board for an EPROM chip. Take a few clear pics of the board and reinstall. Post the pic here if you need help identifying the chip. If it's ECMLink, you'll need a cable from ECMTuning and laptop to connect. From there you can see much more about what's going on. Could be like jdxnc suggested earlier and lost the tune.
Listen to them. Try and start the car on starting fluid. Will point you in a direction quicklyYou must be logged in to view this image or video.
So I connected my laptop has ecmv3 it’s all there connected straight up communicated and gave me all info on what was done still trying to see why it’s not turning over I have ordered plug wires and injector orings I pulled the injectors fuel rail dumped out the gas so I know gas is getting there now trying to figure out if my injectors are spraying
