1G HY35 O2 Housing
thejollyrancher
307
13
Mar 31, 2012
calgary, AB, Canada
Hey,
I have a rebuilt hy35 with what looks like a stock hotside. Can some direct me to an o2 housing thay would connect it a stock dsm downpipe? Or better, direct me to a link of a flange i could use to fab my own o2 housing.
Thanks guys!
I ordered a flange from ebay but it turned out to be different. I was wondering if someone could direct me to one that will be known to work
I'm in the same boat. From what I can tell, a 5 bolt outlet flange for a T3 is similar, but I can't say that they're the same. If they're not, you can get an hx35 outlet flange at mandrel-bends.com
Nothing from a Garrett will directly-fit a Holset.
HX/HY35 outlet flanges are the same.
Yea. From what I have heard there's a shop getting ready to offer one.
It would have to have a v-band on it, exactly the same the flanges that already exist....reason being nobody can take into consideration the angle of every customer's manifold- so you'll either end up with an o2 housing that sits out from the downpipe by 2" or hits the block / oil pan.
http://www.ebay.com/itm/Holset-Down...5-HX35-HE351ve-HE351VGT-Cummins-/141639587632
Yea mines 3.5 comes out and goes down. I built the rest out the bumper. Wrapped it with header wrap. And use a turbo blanket. As well as header wrap on the header. O2 Should work fine for most peeps.
