hp rating for a stock 6 bolt crank?
c_k06
132
Mar 10, 2009
clarksville, Indiana
Ok my engine just took a crap on me and I'm not gonna re-build it stock. I found eagle h-beam rods and wiseco forged pistons that I want but I need to know how much the stock crank can take. I want to be layin down around 400-500 at the wheels. Any advise for anything?
For your goal, a spec'd stock crank is all you need.[/QUOTE]
Spec'd? What does that mean. and i found the eagle rods and wiseco pistons but i dont think the rods come with bearings. Where can i get the right bearings? Also can i just clean up the crank that i have now or do i have to machine it. it looks pretty good. I have an extra block that i will use and build so that i dont have to have my car apart for a long time i can just build the block and swap it out in a weekend or two.
here is where i gound the pistons
http://www.nolimitmotorsport.com/wiseco/apps-Mitsubishi.html
(K559M85) are the ones im looking at
here is where i found the rods
http://www.stikiller.com/product.php?productid=16659
What do you think??
Make sure your car is a 6 bolt before buying rods and pistons. For your goal, you don't even need to buy rods or pistons.
how did the engine take a crap? spun rod bearing, rod in the block, or just burns oil?
you may just want to find a new set of 2g pistons and use your rods if they are in good shape.
if you do end up going with the eagle, and wiseco setup then you will need to have it fully balanced, if you want to get high milage out of it.
i was on the highway going 80 and the oil cooler behind the filter came undone. the bolt holding it on backed off about an inch and the oil dumped out. i shut it off within like 10 seconds of noticing my oil pressure and coasted till i stopped. i took it home figured out the problem torqued it to specs and got a new filter and oil and started it up. I have a knocking sound and my dipstick and oil cap both have horrible blowby. my dipstic looks like an exhaust pipe with oil and gas popping out of it. i just rebuilt it 4000 miles ago so if this time im not going stock.
its a 6 bolt.
its a 6 bolt.
If you're knocking, chances are the crank isn't good in its current shape.
ill second that
personal experience with a 20valve 4age
my x mr2 did the same thing to me a while back, i didnt have oil pressure gauge though. (the sensor went out earlier that week)
i threw some new bearings in.. the crank ground the new ones out in under a month.
i loved that car
if your crank is boned, get a stock one and have it checked out like stated above.
Yes of coarse the crank is not good in its shape but it just needs a little machine work. I did the same thing as him years back and welded the number one rod to the crank. Cheap machine shop visit and good as new.
On a side note the 6 bolt crank has held up to some very high HP numbers in the 2.0L setup. Some even think the 7 bolts are stronger as long as you take care of the over rated crank walk problem.
There's nothing wrong with cutting the crank. It was $20 cheaper for me than a used $150 crank with unvouched history. Plus I got the magnaflux and proof that it was perfectly straight included, as anyone would when a reputable shop cuts down a crank.
