How's my HY35 Oil Setup?
thejollyrancher
307
13
Mar 31, 2012
calgary, AB, Canada
Hey guys,
I just did a load of reading and I think my brain is officially numb. Here's what I've come up with. Im going to set up a 16an drain as Ive read 12 can be too small and 14 is nowhere to be found. My oil inlet will be this one from ExtremePSI: http://www.extremepsi.com/store/product.php?productid=17334&cat=1809&page=1
I'll check oil pressure and all that when I get it all setup, but before I go ahead and order all this stuff, how does it sound? I am removing my balance shafts this winter as well.
I'm not sure what size that line is, but as long as it's bigger than -3 you'll be fine. Don't worry about the -16, -12 is plenty fine as long as its a nice flowing setup with no sharp bends or kinks.
I feed mine a -4 un restricted probably over 100psi oil pressure, and run a -12, that has parts that are probably 5/8" id. It's fine.
There was a whole lot of talk about how crucial oiling is on these things so Im just trying to be super careful. Do you feed from the OFH or the head?
Ill keep that in mind. Im rebuiding the turbo and getting everythin set up this winter. Good to know the oil situation checks out. Thanks!
