Hows it lookin?
mitsukid02
88
Dec 29, 2011
Boston, Massachusetts
Any Advice/ suggestions? This is about 20 psi on 93 pump on a 20g, im ordering a devilsown kit and holset hx35 and plan to run 32 psi
you didn't have any knock so that is always good. what I noticed at the beginning of the log your air flow per rev was high like .45-.50 you want it to be around .25 and combined fuel trim to be close to 0 percent. use maf comp adjust to get your air flow per rev down, once you do that adjust your dead time under fueling to get your combined fuel trim close to zero percent.
hope that helps
    • Sdcryan1
