hows this log look
grizzly
113
Mar 30, 2004
chicago, Illinois
timing o2 rpm knock
33° 0.92V 3438 0
33° 0.92V 3438 0
34° 0.92V 3438 0
34° 0.92V 3469 0
35° 0.92V 3438 0
36° 0.92V 3406 0
36° 0.94V 3438 0
37° 0.94V 3438 0
37° 0.92V 3469 0
37° 0.92V 3469 0
30° 0.92V 3469 0
26° 0.92V 3500 0
26° 0.92V 3500 0
25° 0.92V 3500 0
25° 0.92V 3500 0
25° 0.92V 3500 0
24° 0.92V 3531 0
24° 0.92V 3563 0
23° 0.92V 3594 0
22° 0.92V 3563 0
22° 0.92V 3594 0
21° 0.92V 3656 0
20° 0.92V 3625 0
19° 0.92V 3656 0
19° 0.92V 3625 0
17° 0.92V 3688 0
16° 0.92V 3594 0
15° 0.92V 3688 0
15° 0.92V 3688 0
15° 0.92V 3688 0
16° 0.90V 3781 0
15° 0.92V 3719 0
16° 0.90V 3719 0
16° 0.90V 3750 0
16° 0.90V 3781 0
16° 0.90V 3875 1
15° 0.90V 3844 1
15° 0.90V 3875 1
15° 0.90V 3875 1
15° 0.90V 3938 1
15° 0.90V 3938 0
15° 0.88V 3906 0
15° 0.88V 4000 0
15° 0.88V 4000 0
15° 0.88V 4000 0
15° 0.88V 4031 0
16° 0.88V 4031 0
15° 0.88V 4125 0
16° 0.88V 4156 0
17° 0.88V 4156 0
17° 0.88V 4156 0
17° 0.88V 4156 0
17° 0.86V 4250 0
17° 0.86V 4250 0
17° 0.86V 4313 0
18° 0.86V 4344 2
17° 0.86V 4344 1
17° 0.86V 4313 1
17° 0.86V 4344 1
17° 0.86V 4469 1
17° 0.86V 4438 1
17° 0.86V 4438 1
17° 0.86V 4531 0
18° 0.86V 4406 0
18° 0.86V 4469 0
18° 0.86V 4531 0
18° 0.86V 4625 0
18° 0.86V 4531 0
18° 0.86V 4594 0
18° 0.86V 4625 0
18° 0.86V 4594 0
18° 0.84V 4750 0
18° 0.86V 4688 0
19° 0.86V 4656 0
19° 0.86V 4688 0
18° 0.84V 4781 0
19° 0.84V 4875 0
19° 0.84V 4781 0
19° 0.84V 4844 0
19° 0.84V 4906 0
19° 0.84V 4906 0
19° 0.84V 4875 0
19° 0.84V 4938 0
19° 0.84V 4969 0
19° 0.84V 4969 0
19° 0.84V 4938 0
19° 0.84V 5000 0
19° 0.84V 5000 0
19° 0.84V 5063 0
19° 0.84V 5031 0
19° 0.84V 5094 0
19° 0.84V 5063 0
19° 0.84V 5125 0
19° 0.84V 5156 0
19° 0.84V 5156 0
20° 0.84V 5156 0
20° 0.84V 5188 0
20° 0.84V 5188 0
19° 0.84V 5250 0
19° 0.84V 5281 0
21° 0.84V 5313 0
21° 0.84V 5281 0
21° 0.84V 5281 0
21° 0.84V 5344 0
21° 0.84V 5344 0
21° 0.84V 5344 0
21° 0.84V 5406 0
21° 0.84V 5375 0
21° 0.84V 5438 0
21° 0.84V 5500 0
21° 0.84V 5438 0
21° 0.84V 5531 0
21° 0.84V 5469 0
21° 0.84V 5500 0
21° 0.84V 5500 0
21° 0.84V 5563 0
21° 0.84V 5531 0
22° 0.84V 5531 0
22° 0.84V 5625 0
22° 0.84V 5656 0
22° 0.84V 5594 0
22° 0.84V 5563 0
22° 0.84V 5656 0
23° 0.84V 5594 0
23° 0.84V 5719 0
23° 0.84V 5688 0
23° 0.82V 5781 0
23° 0.84V 5813 0
23° 0.82V 5750 0
23° 0.84V 5813 0
23° 0.84V 5781 0
23° 0.82V 5781 0
23° 0.82V 5813 0
23° 0.82V 5844 0
24° 0.84V 5844 0
23° 0.82V 5938 0
23° 0.84V 5875 0
24° 0.82V 5938 0
23° 0.82V 6031 2
23° 0.82V 6000 2
23° 0.82V 5938 1
23° 0.82V 6063 1
23° 0.82V 6063 1
23° 0.82V 6063 1
23° 0.82V 5969 1
23° 0.82V 6031 2
23° 0.82V 6063 2
23° 0.82V 6063 1
23° 0.82V 6031 1
23° 0.82V 6156 1
23° 0.82V 6156 1
23° 0.82V 6188 1
23° 0.82V 6188 1
23° 0.82V 6219 1
24° 0.82V 6156 0
25° 0.82V 6156 0
24° 0.82V 6219 0
24° 0.82V 6313 0
25° 0.82V 6156 0
24° 0.84V 6344 0
Your leaning out after full boost. I don't know if this is on pump or how much boost your running. My advice is get a wideband best money for tuning I've spent.
That looks real good. I have 2g pistons and at only 13psi I get lots of knock right at 6000rpms. The 1g timing map is more aggresive and with the higher compression pistons I cant run to much boost. Andy on the forums told me to pull my base timing back to 2-3* to run more boost. If I was you I would keep it there untill you have something to tune with.
Looks good to me. What injectors are you running (don't see in mod list)?
How do you get so many samples? Jesus, I get a sample per 200-300 rpm. You get one every 20-30!
A side note: have you used your logger to make sure your TPS shows 100% when at WOT?
JayRolla said:
What software and how many sensors do you log. If you log only 3 at a time you should get a good amont of sample rates
If you are responding to me, I use pocketlogger, and I think it may be my shitty palm. I only log RPM timing and knock. I'm heading on to DSMlink in the near future so I don't care that much, that's just a LOT of samples per second!
WOT?
i watch my safc to make sure i am at 100% wot and i have evo 8 injectors they're 560 belive.
What is your injector duty cycle? That turbo can definitely push a lot more, and if your injectors can handle it, I'd start upping things little by little. You definitely have a solid base setup going. Add a little boost and a little fuel until the injectors are used up.
i have a cheap mbc and thats turned all the way up and i haven't checked inj duty cycle but i think there maxed out cause anything over 15 like when it creeps to 16 and stays there during cold mornings i'll get a little knock. maybe if i get an afpr i could up the pressure and it would help but i know im gonna need bigger inj.
and since my tune is decent now i'm gonna hit the track.
