This log look ok?
Dream On
2,242
23
Sep 6, 2003
Athens/Oxford, Ohio
Hey guys. I've been running my car at wastegate pressure and my car is pretty much stock. It would get a 1 count of knock at certain points in the RPM band, which I didn't think was too big of a deal. I turned up the boost a little to around 13-14 psi or so. It still knocks a small amount, but does this look ok to leave my boost at? I don't have anything to tune with yet, so I can't adjust anything except the boost. :(
TIMA RPM KNCK INJP INJD
35° 2469 0 3.33ms 6
35° 2469 0 3.07ms 6
35° 2469 0 3.33ms 6
35° 2469 0 3.33ms 6
35° 2469 0 3.33ms 6
35° 2469 0 3.33ms 6
35° 2469 0 3.33ms 6
35° 2469 0 3.07ms 6
35° 2469 0 3.07ms 6
35° 2469 0 3.07ms 6
35° 2469 0 3.33ms 6
35° 2469 0 3.33ms 6
34° 2500 0 5.89ms 12
27° 2531 0 6.14ms 12
26° 2531 0 6.66ms 14
25° 2594 0 7.68ms 16
26° 2625 0 7.94ms 17
25° 2656 0 8.19ms 18
24° 2688 0 8.45ms 19
24° 2719 0 7.94ms 18
23° 2781 0 8.19ms 19
22° 2813 0 8.70ms 20
22° 2875 0 8.96ms 21
21° 2906 0 9.22ms 22
21° 2938 0 9.98ms 24
20° 3000 0 10.75ms 27
19° 3063 0 11.78ms 30
18° 3094 0 12.80ms 33
16° 3188 0 13.57ms 36
16° 3250 0 14.08ms 37
15° 3281 0 15.10ms 41
14° 3344 0 15.62ms 43
14° 3406 0 15.87ms 44
14° 3469 0 15.62ms 44
14° 3594 0 15.10ms 44
14° 3594 0 15.36ms 45
15° 3688 0 15.36ms 47
15° 3750 0 15.36ms 48
16° 3813 0 15.36ms 48
16° 3906 0 15.62ms 51
16° 3969 0 15.62ms 51
17° 4000 0 15.87ms 52
17° 4063 0 15.87ms 53
17° 4156 0 15.87ms 55
17° 4219 0 16.13ms 56
17° 4281 0 16.13ms 57
17° 4313 1 16.38ms 59
16° 4375 1 16.64ms 60
16° 4469 1 16.90ms 62
17° 4531 0 16.90ms 63
17° 4531 0 17.15ms 65
17° 4594 0 16.90ms 64
17° 4656 0 17.15ms 66
17° 4719 0 17.15ms 67
18° 4750 0 17.66ms 69
18° 4813 0 17.66ms 70
18° 4844 0 17.92ms 72
18° 4938 0 17.66ms 73
18° 4906 0 17.66ms 72
18° 5000 0 17.66ms 73
18° 5063 0 17.66ms 74
19° 5125 0 17.92ms 76
19° 5156 0 17.66ms 76
19° 5281 0 17.92ms 79
20° 5281 1 17.66ms 77
20° 5344 1 17.92ms 80
20° 5406 1 17.92ms 80
21° 5406 1 17.66ms 80
21° 5500 0 17.66ms 80
21° 5594 0 17.66ms 82
21° 5625 0 17.66ms 83
22° 5625 0 17.41ms 81
22° 5688 0 17.41ms 82
22° 5750 0 17.41ms 83
22° 5844 0 17.41ms 84
22° 5906 0 17.15ms 84
21° 5875 1 17.15ms 83
22° 5906 1 17.41ms 85
22° 6000 1 17.15ms 85
22° 6031 0 16.90ms 84
23° 6063 0 17.15ms 87
23° 6094 0 16.90ms 86
22° 6125 0 17.15ms 87
22° 6219 0 17.15ms 88
22° 6250 0 16.90ms 87
21° 6281 0 17.15ms 90
21° 6375 0 17.15ms 90
20° 6344 0 17.15ms 90
20° 6375 0 17.15ms 90
20° 6438 0 16.90ms 90
20° 6438 0 17.15ms 91
20° 6406 0 17.15ms 91
19° 6438 0 16.64ms 89
19° 6500 0 16.90ms 91
19° 6594 0 16.90ms 93
19° 6656 0 16.90ms 94
19° 6719 0 16.64ms 93
19° 6688 0 16.38ms 91
18° 6719 0 16.64ms 93
18° 6813 0 16.64ms 94
19° 6750 0 16.64ms 94
18° 6844 0 16.64ms 94
18° 6875 0 16.13ms 92
18° 6906 0 16.64ms 95
18° 6906 0 16.13ms 93
EDIT: I was wondering why my timing is being pulled in certain places when I'm only getting 1 count of knock but not in others...I thought that the ECU didn't start pulling timing until it got to 3 counts of knock or so. Anybody?
The 1G ecu pulls 1 degree of timing for ever 2.88 counts of knock. With 1 count of knock it will pull 1/3 degree of timing. Your logger can not read fractions of a degree, so it rounds it out. That's why it seems to pull out 1 degree at 5906 rpm. It was probably at 21.7 degrees of timing, then it pulled .33 degrees out when it saw 1 knock, so the timing went down to 21.4. It's just averaging- don't sweat it.
The ecu will also use less timing at higher airflow, like during spoolup, which occurs around 2500 rpm to 3300rpm in your log.
The stock 1G ecu also pulls timing above 6k rpm. That's the way the timing map is programmed. Yes it sux to see timing drop from 23 to 18 as rpms go up. Your log is almost a perfect copy of the timing advance programmed into the ecu at high load. This is a good reason to get some sort of tuning device. When it comes to tuning devices, more complex=more control but also=more ways to mess it up if you don't know what you're doing.
That's a 3rd gear pull. Is my injector duty a little high for 13-14 psi and stock 450 cc injectors? As for the timing going up to around 24 and then going back down when above 6000 rpm, can a tuning device like a SAFC even change that? I'm thinking of getting a MAF Gen 2 which does basically the same thing as a MAFT and a SAFC in one. It can't control timing though, so will my timing stay the same as it is now?
It's already there. It's the far right column. Just add a % sign and there you go. When I log injector duty cycle with my logger, it also logs the pulse width.
Yes, your timing will stay about the same. There is one thing you can do with a SAFC to help the top end pull. Lean out the 7k rpm/ hi throttle point by about 10% more than the other settings. This usually doesn't change the timing at all, but it keeps the power from dropping off so bad.
I'd really like to be able to be able to adjust timing, but I don't know if I can justify the extra price since in the end I only want to max out the 14b or possibly use an evo III.
Hey! we're back :)
If you don't go bigger than a 16g, then you won't really need to adjust individual timing points by much. It's only when you go bigger that you REALLY need better control of the timing map.
